FPGA Intellectual Property
6670 Discussions
Clock Assignment on (X,Y) region for DDR3 SDRAM Controller with UniPHY IP in Arria V
can anyone please help explain how does the tool go about the (x,y) coordinate of region to decide which fractional pll the clock will use to output clock to logic?
I am targeting Arria V GX 896-pin device, and placing the DDR3 memory interface on Banks 3A, 3C, 3D, 4C, and 4D.
I can't find the constraint anywhere in the SDC to lock the PLL location, but I have narrow it down to the clock pin must be connected at the pin where it has input of DLL_X4_Y0_N0/DLL_X94_Y0_N0, and the adjacent dedicated clock pin which has access to only DLL_X94_Y0_N0 won't work, in the mean time, these two clock pins both have access to the Global/Quadrant and all of the Spine <index> will lead to the following error.
Hence, moving back forth between the two clock pins will get me either a successful compilation, or the transcript below.
Is there a file I have overlooked that carries the pin-constraint on the PLL location for specific device family?
please see transcript below (sorry for the smiley faces):
Info (175028): The PLL LVDS output name: q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_pll0:pll0|pll2_phy~PLL_LVDS_OUTPUT
Info (175013): The PLL LVDS output is constrained to the region (0, 13) to (0, 15) due to related logic
Info (175034): Assignment 1: Region must be in (0, 12) to (0, 15) due to the signal(s) routed from fractional PLL q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_pll0:pll0|pll1~FRACTIONAL_PLL to the PLL LVDS output
Info (175013): The fractional PLL is constrained to the region (0, 8) to (0, 24) due to related logic
Info (175014): Region must be within (0, 8) to (0, 24) due to the signal(s) routed from pin clkintop_100_p to the fractional PLL
Info (175015): The I/O pad is constrained to the location PIN_AJ28 due to: User Location Constraints (PIN_AJ28)
Info (175034): Assignment 2: Region must be in (0, 13) to (0, 15) due to the signal(s) routed from the PLL LVDS output to PHY_CLKBUF q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_p0:p0|q_sys_mem_if_ddr3_emif_0_p0_memphy:umemphy|q_sys_mem_if_ddr3_emif_0_p0_new_io_pads:uio_pads|q_sys_mem_if_ddr3_emif_0_p0_altdqdqs:dq_ddio[3].ubidir_dq_dqs|altdq_dqs2_acv_arriav_quarter_rate_mode:altdq_dqs2_inst|phy_clkbuf
Info (175013): The PHY_CLKBUF is constrained to the region (2, 0) to (41, 0) due to related logic
Info (175014): Region must be within (2, 0) to (41, 0) due to the signal(s) routed from the PHY_CLKBUF to Leveling Delay Chain q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_p0:p0|q_sys_mem_if_ddr3_emif_0_p0_memphy:umemphy|q_sys_mem_if_ddr3_emif_0_p0_new_io_pads:uio_pads|q_sys_mem_if_ddr3_emif_0_p0_altdqdqs:dq_ddio[3].ubidir_dq_dqs|altdq_dqs2_acv_arriav_quarter_rate_mode:altdq_dqs2_inst|leveling_delay_chain_dqs
Info (175013): The Leveling Delay Chain is constrained to the region (40, 0) to (40, 0) due to related logic
Info (175034): Assignment 1: Region must be in (9, 0) to (86, 0) due to the signal(s) routed from DLL q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|altera_mem_if_dll_arriav:dll0|dll_wys_m to the Leveling Delay Chain
Info (175013): The DLL is constrained to the region (4, 0) to (4, 0) due to related logic
Info (175014): Region must be within (4, 0) to (4, 0) due to the signal(s) routed from fractional PLL q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_pll0ll0|pll1~FRACTIONAL_PLL to the DLL
Info (175014): Region must be within (0, 8) to (0, 25) due to the signal(s) routed from pin clkintop_100_p to the fractional PLL
Info (175034): Assignment 2: Region must be in (40, 0) to (40, 0) due to the signal(s) routed from the Leveling Delay Chain to DQS Group fed by DQS I/O pad ddr3_dqs_p[3]
Info (175015): The I/O pad is constrained to the location PIN_AF22 due to: User Location Constraints (PIN_AF22)
Error (175006): Could not find path between the PLL LVDS output and destination PHY_CLKBUF
Info (175027): Destination: PHY_CLKBUF q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_p00|q_sys_mem_if_ddr3_emif_0_p0_memphy:umemphy|q_sys_mem_if_ddr3_emif_0_p0_new_io_pads:uio_pads|q_sys_mem_if_ddr3_emif_0_p0_altdqdqs:dq_ddio[2].ubidir_dq_dqs|altdq_dqs2_acv_arriav_quarter_rate_mode:altdq_dqs2_inst|phy_clkbuf
Info (175013): The PHY_CLKBUF is constrained to the region (41, 0) to (41, 0) due to related logic
Info (175014): Region must be within (41, 0) to (41, 0) due to the signal(s) routed from the PHY_CLKBUF to Leveling Delay Chain q_sys:u0|q_sys_mem_if_ddr3_emif_0_0002:mem_if_ddr3_emif_0|q_sys_mem_if_ddr3_emif_0_p00|q_sys_mem_if_ddr3_emif_0_p0_memphy:umemphy|q_sys_mem_if_ddr3_emif_0_p0_new_io_pads:uio_pads|q_sys_mem_if_ddr3_emif_0_p0_altdqdqs:dq_ddio[2].ubidir_dq_dqs|altdq_dqs2_acv_arriav_quarter_rate_mode:altdq_dqs2_inst|leveling_delay_chain_dqs
Info (175013): The Leveling Delay Chain is constrained to the region (72, 0) to (72, 0) due to related logic
Info (175034): Assignment 2: Region must be in (72, 0) to (72, 0) due to the signal(s) routed from the Leveling Delay Chain to DQS Group fed by DQS I/O pad ddr3_dqs_p[2]
Info (175015): The I/O pad is constrained to the location PIN_AG15 due to: User Location Constraints (PIN_AG15)
Error (175022): The PLL LVDS output could not be placed in any location to satisfy its connectivity requirements
Error (175022): The PHY_CLKBUF could not be placed in any location to satisfy its connectivity requirements
Info (175029): 3 locations affected
Info (175029): PLLLVDSOUTPUT_X0_Y13_N2
Info (175029): PLLLVDSOUTPUT_X0_Y14_N2
Info (175029): PLLLVDSOUTPUT_X0_Y15_N2
Error (171000): Can't fit design in device
Hello I have exactly the same problem. Did you find solution for this issue please?
Thank you very much.
You can try to lock the PLL location through Assignment Editor. Find the PLL node in the RTL, and then locate in Assignment Editor and set the location.
