FPGA Intellectual Property
6673 Discussions
Compile - Error (10481): VHDL Use Clause error at auk_ddr_controller.vhd(35):
Hey, sorry, I just want to bring this over to the IP Discussion forum. Problem is here:
http://www.alteraforum.com/forum/showthread.php?t=4665 (http://www.alteraforum.com/forum/showthread.php?t=4665
I'm trying to compile the PCIe to DDR2 reference design and Quartus gives the following error:
Info: Found 2 design units, including 1 entities, in source file auk_ddr_controller.vhd Info: Found design unit 1: auk_ddr_controller-rtl Info: Found entity 1: auk_ddr_controller Error (10481): VHDL Use Clause error at auk_ddr_controller.vhd(35): design library "auk_ddr_lib" does not contain primary unit "auk_ddr_functions" Error (10800): VHDL error at auk_ddr_controller.vhd(35): selected name in use clause is not an expanded name
Since the whole mess is generated by the DDR2 controller MegaFunction and presumably brought in all the settings when I converted from the 7.1 to the 8.0 SP1 Megacore IP, I'm not sure how to proceed.
Thanks for your help.
Leslie
Try deleting the db directory and recompiling.
I am seeing the same problem. I just downloaded Quatrus II 9.0 and tried to build nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost. I got exactly the same error. I tried renaming the nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost\db directory and no change.
I am running the Quatrus Web edition 9.0 on Vista.
Any ideas?
--- Quote Start ---
--- Quote End ---
Didn't work.
See my reply to the next post.
--- Quote Start ---
Any ideas?
--- Quote End ---
Yes, I figured it out. See this post.
The example project I was building was supposed to have been compiled by Altera under Quartus II 8.0. I'm sure it did. However, the designer probably still had 7.2 installed on his/her computer. Some of the megafunctions were from 7.2 and still referenced the old path. So they wouldn't compile on my computer. The error message was fairly cryptic.
Hmmm, maybe I also had to add a library to the project... the 7.2 megafunctions were archived in a subdirectory but I didn't notice until I'd already taken the other approach.
I can't guarantee that's your problem, too, but it's worth a shot. Try recompiling or recreating the megafunctions in your design.
Cool,
Same error I'm getting (not using Vista). I am trying to compile an example problem so it sound like I have to locate the line in the code that is referencing a none existent link and substitute in a correct link for Quartus 9.0...
--- Quote Start ---
--- Quote End ---
I'm having the same problem. However, I'm new to NIOS II, and have never used the MegaWizard or SOPC Builder. Can someone please instruct me on how I would "recompile or recreate" the megafunctions to work with 9.0 and my DE2_70 Development board?
Thanks a ton in advance!
-Jorden
I just tried to recompile C:\altera\90sp2\nios2eds\examples\vhdl\niosII_cycloneII_2c35\standard
With Qaurtus(+Nios) 9.0sp2
And I get same error although ddr_sdram_controller-library is in Project libraries (already in Assignments settings).
I success compiling by :
backup the altera example first !
* removing db, incremental_db folders
* regenerating SOPC (with Sopc Builder)
I have warning messages.
I don't sure it is working good
