Hey, sorry, I just want to bring this over to the IP Discussion forum. Problem is here:
http://www.alteraforum.com/forum/showthread.php?t=4665 (http://www.alteraforum.com/forum/showthread.php?t=4665) I'm trying to compile the PCIe to DDR2 reference design and Quartus gives the following error:Info: Found 2 design units, including 1 entities, in source file auk_ddr_controller.vhd
Info: Found design unit 1: auk_ddr_controller-rtl
Info: Found entity 1: auk_ddr_controller
Error (10481): VHDL Use Clause error at auk_ddr_controller.vhd(35): design library "auk_ddr_lib" does not contain primary unit "auk_ddr_functions"
Error (10800): VHDL error at auk_ddr_controller.vhd(35): selected name in use clause is not an expanded name
Since the whole mess is generated by the DDR2 controller MegaFunction and presumably brought in all the settings when I converted from the 7.1 to the 8.0 SP1 Megacore IP, I'm not sure how to proceed. Thanks for your help. Leslie
Try deleting the db directory and recompiling.
I am seeing the same problem. I just downloaded Quatrus II 9.0 and tried to build nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost. I got exactly the same error. I tried renaming the nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost\db directory and no change.
I am running the Quatrus Web edition 9.0 on Vista. Any ideas?- Mark as New
--- Quote Start --- Try deleting the db directory and recompiling. --- Quote End --- Didn't work. See my reply to the next post.
--- Quote Start --- I am seeing the same problem. I just downloaded Quatrus II 9.0 and tried to build nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost. I got exactly the same error. I tried renaming the nios2eds\examples\verilog\niosII_cycloneII_2c35\low_cost\db directory and no change. I am running the Quatrus Web edition 9.0 on Vista. Any ideas? --- Quote End --- Yes, I figured it out. See this post. http://www.alteraforum.com/forum/showthread.php?t=4665 (http://www.alteraforum.com/forum/showthread.php?t=4665) The example project I was building was supposed to have been compiled by Altera under Quartus II 8.0. I'm sure it did. However, the designer probably still had 7.2 installed on his/her computer. Some of the megafunctions were from 7.2 and still referenced the old path. So they wouldn't compile on my computer. The error message was fairly cryptic. Hmmm, maybe I also had to add a library to the project... the 7.2 megafunctions were archived in a subdirectory but I didn't notice until I'd already taken the other approach. I can't guarantee that's your problem, too, but it's worth a shot. Try recompiling or recreating the megafunctions in your design.
Cool,
Same error I'm getting (not using Vista). I am trying to compile an example problem so it sound like I have to locate the line in the code that is referencing a none existent link and substitute in a correct link for Quartus 9.0...- Mark as New
--- Quote Start --- Yes, I figured it out. The example project I was building was supposed to have been compiled by Altera under Quartus II 8.0. I'm sure it did. However, the designer probably still had 7.2 installed on his/her computer. Some of the megafunctions were from 7.2 and still referenced the old path. So they wouldn't compile on my computer. The error message was fairly cryptic. Hmmm, maybe I also had to add a library to the project... the 7.2 megafunctions were archived in a subdirectory but I didn't notice until I'd already taken the other approach. I can't guarantee that's your problem, too, but it's worth a shot. Try recompiling or recreating the megafunctions in your design. --- Quote End --- I'm having the same problem. However, I'm new to NIOS II, and have never used the MegaWizard or SOPC Builder. Can someone please instruct me on how I would "recompile or recreate" the megafunctions to work with 9.0 and my DE2_70 Development board? Thanks a ton in advance! -Jorden
I just tried to recompile C:\altera\90sp2\nios2eds\examples\vhdl\niosII_cycloneII_2c35\standard
With Qaurtus(+Nios) 9.0sp2 And I get same error although ddr_sdram_controller-library is in Project libraries (already in Assignments settings). I success compiling by : backup the altera example first ! * removing db, incremental_db folders * regenerating SOPC (with Sopc Builder) I have warning messages. I don't sure it is working good
