FPGA Intellectual Property
6670 Discussions
Convert m file to verilog/vhdl?
Hi Guys,
Is there any way to convert Matlab .m code to verilog or vhdl? Does DSP builder only compile simulink file?
Jerry
its not even as simple as that.
M code is inherently procedural, like C. VHDL/verilog are description languages and are parallel languages. If you want to convert from simulink to HDL code you have to design your algorithm appropriatly, usually with the involvement of a hardware engineer.
