FPGA Intellectual Property
Cordic/Divider
SGold21
I understand that there are cores for cordic (I need atan2) and integer divider.
Are there any matlab models available for verification purposes?
CheePin_C_Intel
As I understand it, you are inquiring if there is any Matlab model for CORDIC Intel FPGA IP. For your information, this IP only support VHDL and Verilog simuulation model but not Matlab model. Sorry for the inconvenience. As a workaround, you may look into using Modelsim to simulate the IP behavior.
Chee Pin
SGold21
If I can't have a C/Matlab model, then I can't use the block. Our methodology requires verification versus C/Matlab model.
CheePin_C_Intel
Sorry for the inconvenience as currently there is no C/Matlab model for this specific IP.
