FPGA Intellectual Property
6365 Discussions
DE2 board Codec help
Hello everyone,
I am trying to interface the wolfson codec in the de2 board. i've written a code to send data the control registers of the codec. since i want to use the microphone i sent data to register4 (boost its volume, demute it, and give priority.
I am using the the code bellow to fetch the data from the audio codec at using the left justified mode at a frequency of 48KHZ in an 8 bit form; but it doesn't seem to work.
Could any one give me a hand please. I am struggling with this codec for more than a week. is there any thing wrong with it or is it soemthing else?
thanks in advance.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity digital_audio_interface is
port(
clk , reset : in std_logic;
adc_data_out : out std_logic_vector(7 downto 0);
m_clk, b_clk, lr_clk : out std_logic;
adcdat : in std_logic;
load_done_tick : out std_logic);
end digital_audio_interface;
architecture arch of digital_audio_interface is
constant m_dvsr: integer := 2;
constant b_dvsr: integer := 3;
constant lr_dvsr: integer := 5;
signal m_reg , m_next : unsigned(m_dvsr-1 downto 0);
signal b_reg, b_next : unsigned(b_dvsr -1 downto 0);
signal lr_reg, lr_next : unsigned(lr_dvsr - 1 downto 0);
signal neg_lr_clk : std_logic;
signal adc_buf_reg, adc_buf_next : std_logic_vector(15 downto 0);
signal lr_delayed_reg, b_delayed_reg: std_logic;
signal load_tick, m_12_5m_tick: std_logic;
signal b_neg_tick, b_pos_tick : std_logic;
signal data_out_reg, data_out_next : std_logic_vector(7 downto 0);
begin
-- clk signals for codec digital audio interface
--registers
process(clk, reset)
begin
if reset ='1' then
m_reg <= (others => '0');
b_reg <= (others => '0');
lr_reg <= (others => '0');
adc_buf_reg <= (others => '0');
b_delayed_reg <= '0';
lr_delayed_reg <= '0';
data_out_reg <= (others => '0');
elsif( clk'event and clk = '1') then
m_reg <= m_next;
b_reg <= b_next;
lr_reg <= lr_next;
adc_buf_reg <= adc_buf_next;
b_delayed_reg <= b_reg(b_dvsr - 1);
lr_delayed_reg <= lr_reg(lr_dvsr -1);
data_out_reg <= data_out_next;
end if;
end process;
-- codec 12.5 mhz m_clk (master clock) ideally it should be 12.288
m_next <= m_reg + 1;
m_clk <= m_reg(m_dvsr -1);
m_12_5m_tick <= '1' when m_reg=0 else '0';
-- b_clk (m_clk / 8 = 1.5 mhz)
b_next <= b_reg + 1 when m_12_5m_tick ='1' else b_reg;
b_clk <= b_reg(b_dvsr - 1);
b_neg_tick <= b_delayed_reg and (not b_reg(b_dvsr - 1));
b_pos_tick <= (not b_delayed_reg) and b_reg(b_dvsr - 1);
-- adc/dac_lr_clk (dac_lr_clk/ 32 = 48 khz)
lr_next <= lr_reg + 1 when b_neg_tick = '1' else lr_reg;
lr_clk <= lr_reg (lr_dvsr - 1);
neg_lr_clk <= lr_reg(lr_dvsr-1);
--completion of one mono sound
load_tick <= ( (lr_delayed_reg)) and (not (lr_reg(lr_dvsr - 1)));
load_done_tick <= load_tick;
adc_buf_next <= adc_buf_reg(14 downto 0) & adcdat when (b_pos_tick = '1' and neg_lr_clk = '1') else
adc_buf_reg;
adc_data_out <= data_out_reg(15 downto 8);
end arch;
Hello everyone,
I realize the mistake was not in this code, data is fetched at the rate expected meaning 48 Khz.
I used a downsampler to reduce the sampling rate into 8 Khz. that was the problem.
Hello studmad,
i need to store the digtal data from Codec into memory, can you help me out.
