FPGA Intellectual Property
6670 Discussions
DHCP times out in ethernet example
I try to run the example "Nios II Ethernet Simple Socket Server
on MAX 10 FPGA Development Kit". However, instead of
"Acquired IP address via DHCP client for interface: et1¨
in step 7 of the manual I get after some time
"DHCP timed out, going back to default IP address(es)"
How can I
1) make DHCP not time out, or
2) discover what the "default IP address" is?
Thanks in advance for answering.
As a first step, use an Ethernet analysis tool to verify your packets are correct. Wireshark is good. I like to use it in a bridge configuration between the device and the network. See the Wireshark documentation for details on how to set up a bridge.
Thanks for your help. I finally solved the problem as follows:
- Disabling DHCP in the BSP
- Giving the PC a fixed IP address
I do not know why this works, although I can imagine that
things get less complicated due to these measures. At least now
it is fun to follow the simple communication with Wireshark.
