FPGA Intellectual Property
FFT IP core and QSYS
Could anyone explain me how do I connect FFT IP core in QSYS? I have tried to use SGDMA but the bits/symbol doesn't match. I don't have DSP Builder.
The FFT is Avalon ST compliance, this is depending on your application to determine how to connect the FFT IP, do you need store data in External Memory? if no, then I don't think you need SGDMA. Or you may just export the avalon ST port to the top level
I solved it. I wrapped Megacore code with a template and used scgdma with some adapters.
hi,i also use fft ip and connect it to nios through sgdma. however, i load to the development kit and the result is not correct.
i make a component of fft and connect it to qsys; in creating component, i only add the wrapper(my_fft.v) and fft ip top file(fft512.v) as follow, i am not sure it can call the fft lib and synthesize the correct hardware.
http://www.alteraforum.com/forum/attachment.php?attachmentid=10816&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=10817&stc=1
http://www.alteraforum.com/forum/attachment.php?attachmentid=10818&stc=1
i load to development kit ,but the result is wrong like this , could you give me some help. Thank you very much.
http://www.alteraforum.com/forum/attachment.php?attachmentid=10819&stc=1
my wrraper code:
module my_fft ( clk, reset_n, sink_valid, sink_sop, sink_eop, sink_in, sink_error, in_empty, source_ready, sink_ready, source_error, source_sop, source_eop, source_valid, source_out, out_empty); input clk; input reset_n; input sink_valid; input sink_sop; input sink_eop; input sink_in; input sink_error; input in_empty; input source_ready; output sink_ready; output source_error; output source_sop; output source_eop; output source_valid; output source_out; output out_empty; wire sink_real; wire sink_imag; wire source_real; wire source_imag; wire source_exp; assign {sink_real,sink_imag} = sink_in; assign source_out = {source_real,source_imag}; assign out_empty = (source_eop)?2'b0:2'b0; fft512 fft512_int( .clk(clk), .reset_n(reset_n), .inverse(1'b0), //use fft .sink_valid(sink_valid), .sink_sop(sink_sop), .sink_eop(sink_eop), .sink_real(sink_real), .sink_imag(sink_imag), .sink_error(sink_error), .source_ready(source_ready), .sink_ready(sink_ready), .source_error(source_error), .source_sop(source_sop), .source_eop(source_eop), .source_valid(source_valid), .source_exp(source_exp), //not used .source_real(source_real), .source_imag(source_imag) ); endmodule
i make a component of fft and connect it to qsys; in creating component, i only add the wrapper(my_fft.v) and fft ip top file(fft512.v) as follow(not add the file of fft lib ), i am not sure it can call the fft lib and synthesize the correct hardware.
my wrraper code:
--- Quote Start ---
--- Quote End ---
What adapters changed the bits per symbol between memory and the FFT core?
--- Quote Start ---
--- Quote End ---
Hi. I don't remember exactly the problem I had. It was a long time ago. But, checking Qsys I realized I am using mSGDMA instead of SGDMA. Both FFT and mSGDMA are configured with 8 data bits per symbol. There are two adapters that are being automatically inserted by Qsys. They are about a 3 bits empty signal that mSGDMA has, but FFT doesn't.
