Hi
I am using DSP Builder 11. When I am trying to compile my design, the Quartus error I receive is: Error: IP Generator Error: Entity ' ' (Version latest) not found in librarian. I found a note in the Altera Web site regarding this issue but it is not relevant to me, as I do not have such a folder (.altera.quartus). (could this be the problem?) Any help to at least of the above question will help me a lot. Thank you in advance, AhmedLink Copied
The .altera.quartus problem went away a few years ago. You shouldn't see it with DSP Builder 11.0.
Do you see this problem with any design or just one in particular? Try creating a very simple design with just an input port connected to an output port and see if that compiles.- Mark as New
Do you use a imported Megacore or VHDL code? If this is the case run
alt_dspbuilder_refresh_HDLimport
for imported VHDL code or alt_dspbuilder_refresh_megacore
for imported Megacore in the Matlab command window to rebuild the dependencies for these blocks.
