FPGA Intellectual Property
6673 Discussions
Deo nano board help!
Hi! May i know why my deo nano board fail to connet when i test with control panel? USb blaster install succesfully and the light found in the board but it fail to connect...May i know why?
Did you already downloaded .SOF file supplied with the control panel to your FPGA?
Best regards.
do u mean i need to download it?
when you downloaded the whole package of control panel, it already contains the .SOF file. This needs to be used to program you FPGA first. Later, your control panel application will be able to connect to the board.
