FPGA Intellectual Property
6670 Discussions
DeviceIOControl - DMA - Interrupt issues
Here is the logic flow:
1. GUI program sends DeviceIoControl command setup to driver:
setup DMA descriptors
2. GUI program sends DeviceIoControl command Start to driver:
call the routine of start DMA Read and write (with parameter of# of loops)
3. ISR routine receives interrupts
Checks# of loops, if not, zero, call the same of above routine to restart DMA R/W.
It works only if put a debug line before start DMA:
KdPrintf("."); //if this line is commented, no interrupts will be received.
StartDMA();
Anyone has any suggestions what is wrong?
Tiger
There are two problems: One it needs synchronization, and the other is to check the interrupt status registers, because the interrupt is shared by both read and write. That fixes the problem.
