FPGA Intellectual Property
6670 Discussions
Error when using x1 PCIe in SOPC
I instantiate PCIe core in SOPC following AN532 http://www.altera.com/literature/an/an532.pdf which is using x4 PCIe.
But I configure for my CycloneIV board which has only 1 lane.
I have lots of compilation errors due to some ports are not connected properly. The errors point to SERDES module.
I checked and found that Although the PCIe wizard configures x1 PCIe; but the Transceiver wizard shows that it is configured for x4 PCIe
Any one has similar problem? Thanks
Jeff
--- Quote Start ---
Jeff
--- Quote End ---
I think there's a bug with SOPC, it can't propagate the setting properly. I might have configured it wrong before.
I deleted the module, start again, it's ok now.
