FPGA Intellectual Property
6670 Discussions
FFT megafunction simulation in Modelsim
I'm trying to get a standalone FFT megafunction simulation running in Modelsim Altera Starter 6.5b (generated with QII 9.1, Verilog). I generated the simulation model and compiled the .vo and _tb.v files successfully. Now starting the simulation of the testbench, Modelsim generates dozens of warnings similar to:
# ** Error: (vsim-3033) D:/hardware/components/modelsim/fft64_test.vo(6204): Instantiation of 'altmult_add' failed. The design unit was not found.# Region: /fft64_test_tb/dut# Searched libraries:# D:\hardware\components\modelsim\workNow that would make me believe that some libraries are missing. Modelsim is a fresh install and the FFT user guide doesn't give me any hints on that problem. Do I need to compile something else into my work library?
Any help is greatly appreciated!
Cheers,
Andy
I did some more digging. All necessary libraries are there, I even tried to reference them directly in the modelsim.ini. They all appear in the GUI. However vsim seems to ignore them.
How can I tell Modelsim to use the libs? I didn't find a reference how to do that. The setup seems fine for me...
I have the same problem and i didn't found any solution :mad:. Do you have a idea for me?
I've hit the same problem too. I'm sure there must be a simple solution. I wonder if anyone has a simple, step by step guide explaining the necessary steps to get the FFT IP compiled properly, allowing modelsim simulations.
I am having the same issue, did you guys know were we can get that step-by-step guide??
