FPGA Intellectual Property
6670 Discussions
FFT Simulation Errors—MATLAB Model Mismatch after block floating scaling
Hi everybody,
first of all thx to all the people who will supply an answer! Let me explain the context: I implemented a FFT block using megawizard tool of Quartus, with the following parameters:
■ Transform length: 2048
■ I/O data flow: burst architecture
■ FFT engine architecture: quad output
■ Number of parallel engines: 2
Input of FFT module is a sine at 50 Hz, amplitude = 5 and fixed point data. I stored imaginary, real and exponent data on 3 different files. After that, using the same input file, I calculated FFT using Matlab. I multiplied (scaling operation) Matlab output data by 2^exponent ( -5 in my case).
I realized an excel file where I compare results from Modelsim and Matlab. Many of all ( maybe 97%) are similar: the difference among Modelsim and Matlab data, is at most equal to +/- 2 . Anyway I saw that for some of them there is no correspondance: difference amoung these particular case is equal to +123,-36, -118.
Looking at "Release Notes and Errata" of Megacore IP library, on paragraph "Simulation Errors—MATLAB Model Mismatch", I saw that there could be some problem.
( the link to document is)
http://www.altera.com/literature/rn/rn_ip.pdf
Am i wrong???
no answer????:(
