FPGA Intellectual Property
6670 Discussions
Gate level simulation in ModelSim with DSP Builder generated designs
I try to further verify my design in DSP-Builder by applying gate-level simulation in Altera-ModelSim. But some modules which have no problems in RTL simulation do not work in the port-synthesis and gate-level simulation. I will try to describe my problems and would be grateful if someone could give some hints about how to fix it.
For instance, I have setup a counter in my DSP-Builder and can run the Simulink and rtl simulation on ModelSim without any problems. And then I run the full compilation in Quartus II to generate the vho and sdf files for post-synthesis and gate-level simulation in ModelSim. To do so, I also compile the altera_primitives_component.vhd into the altera library directory in ModelSim, so that I can compile the vho file into the work library. But then I get some warning messages when I run the post-synthesis simulation:
** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[1]\ : dffeas" is not bound.
# Time: 0 ps Iteration: 0 Region: /tb_adder/dut File: C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder.vho
# ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[2]\ : dffeas" is not bound.
# ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[3]\ : dffeas" is not bound.
# ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[4]\ : dffeas" is not bound.
# ** Warning: (vsim-3473) Component instance "\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[5]\ : dffeas" is not bound.
And my counter output become "UUUUUU".
When I try to run a gate-level simulation by further taking the sdf file into the simulation. Then I get the following error messages: ( my counter out is 8 bit, I get error for each bit port, but some messages are omitted here due to their similarities)
# ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1054): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[5]\'.
# ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1089): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[6]\'.
# ** Warning: (vsim-SDF-3250) C:/Work/Matlab/adder/tb_adder/simulation/modelsim/adder_vhd.sdo(1124): Failed to find INSTANCE '\auto_inst|adder_FPGA_0|Counter|Counteri|auto_generated|counter_reg_bit[7]\'.
# ** Warning: (vsim-SDF-3894) : Errors occured in reading and resolving instances from compiled SDF file(s).
My questions are:
What is my problem here, did I forget something?
It seems that modelsim have problem with "dffeas". But what is it?
How should I integrate my DSP-Builder design into my top-level design in Quartus II? Now I use the "export" option of the DSP-Builder Signal Compiler to export the vhdl files to my project and then instantiate my DSP-Builder design. But many modules seem not to be working in the post-synthesis or gate-level simulation , although everything is fine in rtl level simulation.
Many thanks for your helps!
Yang
you shouldn't have to compile any libraries when using ModelSim-AE.
i'm not sure what the problem is but i recommend trying to simulate using the NativeLink flow which usually does a good job setting up the simulation:
http://www.altera.com/literature/hb/qts/qts_qii53001.pdf
Well, the problem is, the automatically generated tcl files does not compile the altera_primitives_components.vhd into the altera library, which is needed for the compilation of the vho file. So I just added this step to get the thing work.
As far as I know, NativeLink is not so flexible as using ModelSim directly. And I could not image if something does not work in ModelSim-AE will work with NativeLink.
Or you could provide me more details about the advantages of using NativeLink? Thank you!
from my previous link:
--- Quote Start ---
In the ModelSim-Altera software, the pre-compiled libraries for both functional and gate-level simulations are available. You do not have to explicitly compile these library files before running the simulation directly.
--- Quote End ---
i agree that NativeLink is not as flexible as using ModelSim or writing your own simulation script, but i often use NativeLink to generate the initial .do file and edit it to taste so i don't have to do the tedious work. :)
