FPGA Intellectual Property
6673 Discussions
Getting started with startix-10 e-tile
yairs
Hi.
I am trying to build a 100ge test equipment using an existing board that have startix10-tx connected to an optical module qsfp28-sr4. I am using the E-Tile Hard IP for Ethernet from the Quartus prime Ip library.
I Have already established the ethernet and transceiver reconfiguration interface, so i can talk to the module.
I Haven't designed the client side (packet generator) yet. I want to verify that the IP is working first.
I have disabled auto neg and link training as otherwise, I am getting a design that is valid for 1 hour only, and RBF building fails. Do I need auto neg for optical connection?
Additionally, I have two questions:
1. I am having trouble measuring my reference clock (should be 156.25M). Is there a way to verify that it is correct?
2. Can anyone provide a simple sequence to get and verify the link up on the transceivers?
Any help and tip will be very appreciated.
Thanks in advance
yair.
Ash_R_Intel
You could try example designs first:
2.3. 100GE with Optional RS-FEC Design Example
Ash_R_Intel
Were you able to try out the example designs?
Ash_R_Intel
As we did not get any further response from you, we are closing the case. However, it will be open for the community members to comment upon.
