FPGA Intellectual Property
6673 Discussions
HDMI BSP Driver No Longer Included in Quartus 23.2 for non-Agilex 7 Targets
dscully
I have a Arria 10 project using the Intel HDMI 2.1 core in AXIS-VVP Full mode. The board support package (BSP) generation reports that the "intel_hdmi21_driver" is detected for inclusion. However, the driver files are never copied into the BPS driver folder during the nios2-bsp-generate-files step.
After investigation, I have found that in 23.2 callback TCL script only adds driver inc/src files for the Agilex 7 device family:
See: intelFPGA_pro\23.2\ip\altera\altera_hdmi\hw_demo\common\software\software_driver\callbacks.tcl
In version 22.4, a callback file was not used and instead the altera_hdmi_sw.tcl script added the headers and source files for the driver unconditionally (i.e., no family check).
Is this a mistake that will be fixed in a future version? If so, is there a workaround that doesn't require modifying the Quartus install TCL file to remove the family check?
Thank you,
David
ZH_Intel
Hi David,
Apologize for the delayed response.
Thank you for your report.
I have forwarded your case to our internal team and they are now running investigation on this.
This investigation process will consume some time on checking this issue.
If our internal team confirm that this a bug, we will fix it in the future release.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi David,
Thank you for reaching out.
Apologize for the delayed response as we encounter some technical difficulty.
Just to let you know that Intel has received your support request and currently we are confirming the details with our internal team.
I shall come back to you with findings.
Thank you for your patience.
ZulsyafiqH_Intel
ZH_Intel
Hi David,
Our internal team are still looking and confirming on this.
Currently am waiting for their response.
Will update you as soon as I have their feedback.
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi David,
Thank you.
ZulsyafiqH_Intel
ZH_Intel
Hi David,
Thank you for your respond.
With your respond to accepted solution, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
ZulsyafiqH_Intel
