FPGA Intellectual Property
6670 Discussions
Hi, While compiling a SOF with JTAG to Avalon master IP. Obtained Warning (12914): The file jtag_master16p0/jtag_master.sopcinfo, is not embedded into sof file as expected. Some tools, such as System Console, may not function fully. Any Solutions ?
NN
And while trying to use the JTAG to Avalon master interface through System console it just hangs for one minute.  Operations are not being completed. I tried searching for this issue in forums but didn't find a solution posted.
AnandRaj_S_Intel
Can you help me to recreate the scenario with more information like.
  1. Quartus version and edition used?
  2. IP's used?
  3. Can you share the project file?
Can you delete the incremental_db and db folder or other quartus version and try?
Also try with example design from below link
https://fpgawiki.intel.com/wiki/Using_the_USB-Blaster_as_an_SOPC/Qsys_Avalon-MM_master_Tutorial
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
