FPGA Intellectual Property
Hil
I have a pipeline fft model that I want to run on a Stratix III FPGA using HIL. I am attaching a screenshot of my models with and without HIL blocks and the HIL configuration. Now I have the HIL configured and programmed to the FPGA. When I run the simulations I see no output in the scope. Where am I going wrong here? The model without HIL shows me the correct output.
https://www.alteraforum.com/forum/attachment.php?attachmentid=3505
https://www.alteraforum.com/forum/attachment.php?attachmentid=3506
https://www.alteraforum.com/forum/attachment.php?attachmentid=3507
i read the forum quite often, please avoid PMs about new threads
the first thing to check the the reset polarity between the original .mdl Clock block and the HIL settings
Thanks for the reply. It is working now.. And sorry abt the PM.. Will not do that again..
was it the reset polarity?
In the clock it was low while in the signal block and HIL config it was high. So changed the clock to high
