FPGA Intellectual Property
6670 Discussions
How can i connect Viterbi IP core with Fifo ??
hi
i have a problem that the viterbi ip core is configured as streaming component, and i want to interface it with nios processor, so to do so i must use on chio fifo in the sopc builder to connect them, but the problem is, when i use fifo to convert form Avalon MM to Avalon ST the data width must be 32, but the viterbi data input is 8 bits only, and it's output is only 1 bit !!!!
howa can i connect those 2 components, i hope that any one has tried this before can answer men :)
