FPGA Intellectual Property
6670 Discussions
How do I select which hard memory controller to use if my FPGA has two controllers?
KMich2
I am using an Arria V GX which is suppose to have 2 hard memory controllers. How do I select which one to activate as the UNIPHY memory controller seems to only work with bank 7 but my memory device is routed to bank 4, which causes a fitter error if I try to use the specified hard memory pins on this bank.
AndyN
What is the fitter error you are getting?
KMich2
Please see my reply below, thanks...
NurAida_A_Intel
Hi KMich2,
As per you said the device have 2 hard memory controllers (HMC), so I assume you are using Arria V GX A1 or A3 Device.
By right, both Bank 4 and 7 is usable for this device.
May I know what is the data width you used and what type of fitter error you seen?
Just for your reference, you may refer to this handbook (page 264) in below link to get more information on Hard Memory Controller in Arria V device.
https://www.intel.com/content/www/us/en/programmable/documentation/sam1403480004852.html#sam1403479856478
NAli1
KMich2
The device I am using is 5AGXMA3D6F27C6.
The controller width is 32, the DQ bus is 16 bits.
The error messages I am getting are as follows:
Error (175006): Could not find path between the HPHY and destination pin
Info (175027): Destination: pin DDR3_CSn
Info (175015): The I/O pad DDR3_CSn is constrained to the location PIN_W13 due to: User Location Constraints (PIN_W13)
Info (14709): The constrained I/O pad is contained within this pin
Error (175022): The HPHY could not be placed in any location to satisfy its connectivity requirements
Info (175021): The pin was placed in location W13
Info (175029): 1 location affected
Info (175029): MEMPHY_X55_Y90_N1
I assume there must be a setting to make the device on bank 4 the master, but it's not clear what this setting should be or how to enter it, as there is no option to select the device in the UniPHY IP wizard, any advice?
NurAida_A_Intel
Hi KMich2,
The Arria V HMC use dedicated I/O pins as data, address, command, control, clock, and ground pins for the SDRAM interface. I have highlighted the hard memory interface pin-out in YELLOW in attached pin-out excel file. Therefore, user shouldn’t be assigning hard memory interface DDR3 pin-out to other pin location anymore. Only dedicated pin-out is acceptable.
I suggest you to modified your design by removing all the pin location assignment for DDR3 IP and re-compile your project.
Hope this helps.
NAli1
KMich2
The pin assignments we are using are in accordance to this table, but for the hard memory controller pins shown on IO bank 4, instead of IO bank 7 (which are automatically assigned by the fitter if we do not constrain the pins). As there are two hard memory controller, how do we get the fitter to use the other one, as our memory chip is wired to IO bank 4 and changing our design is not an option for us.
KMich2
Another question related to this table... How do we invoke the 'optional function' on a pin, for example the VREFB4DN0 on pin AA12. I understand this should be an externally supplied reference voltage for bank 4D at 1/2 the selected IO standard for the bank, but the pin also seems to serve as an IO pin. Do we need to configure the pin to use it as a voltage reference input?
NurAida_A_Intel
Hi KMich2,
Depending on your design, if you used verilog code then you can set the input pin in your RTL ( as shown in Figure 1) , re-compile the design ( compile at Analysis and Synthesis stage will do) and assign this PIN_AA12 as input in your Pin Planner (Figure 2). Then directly connect the VREF to this PIN_AA12. Make sure also the I/O standard is set accordingly with your design. What shown in Figure below is just an example for your reference. 😊
Figure 1:
RTL code.PNGFigure 2:
Pin planner.PNG If you are using the Qsys, then set the input in Qsys.
Hope this helps.
NAli1
KMich2
OK, so I just need to assign the pin as an input and it will act as a reference for all the other pins on the bank? Thanks.
NurAida_A_Intel
​Yes , you are right.
You are most welcome 😊
NAli1
KMich2
I have found a simple workaround:
By reserving one of the pins allocated for the HMC on bank 7 (e.g. the RZQ pin G6) the alternative HMC on bank 4 is automatically chosen during fitting.
Thank you for your responses.
NurAida_A_Intel
​Hi KMich2,
Glad to know that your design is working now.  Thank you for sharing the workaround.  It's really helpful for other user that may encounter the same issue in future. Appreciated your sharing . Thanks and have a nice day 😊
NAli1
