FPGA Intellectual Property
6670 Discussions
How to call an IP designed in Verilog in Intel HLS compiler?
mnazemi
Is it possible to design and optimize an IP in Verilog and create a function for it that can be called from HLS?
A simple example of such scenario would be as follows:
  1. Design and optimize an FIR filter in Verilog.
  2. Create a function for the design in HLS.
  3. Write a nested `for` loop in HLS that calls the function associated with the filter.
MEIYAN_L_Intel
Since you created the design in HDL for a FIR, you can directly use it. You will eventually get HDL after HLS compilation.
