FPGA Intellectual Property
6669 Diskussionen
How to handle such warning message of UniPHY IP
XQSHEN
Anfänger
1.726Aufrufe
Use DDR2 controller with UniPHY
Integerate in platform design with NIOS.
Device used: Max10, 10M16DCU324I7G
Start analysis & Synthesis
4 Antworten
NurAida_A_Intel
Mitarbeiter
1.677Aufrufe
Hi Sir,
It seems to be a variable declaration issue and connectivity issue. I am suspecting this attributed to the warning.
Can the fitter compilation complete without error?-- If Fitter is Passing without error, then you can safely ignore the synthesis warnings.
You may find it useful to run the example design first, check the connection to help understanding and compare with your design.
I am attaching a word document which I centralized all the warnings listed with “CAUSE” and “ACTION” to help handle the warnings.
Hope this helps.
Aida
NurAida_A_Intel
Mitarbeiter
1.677Aufrufe
Hi Sir,
As there has been no update from you recently, I am assuming that the information I provided has helped you to resolve your issue. I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
XQSHEN
Anfänger
1.677Aufrufe
I still have problem , but I don't find where can set it in assignment editor.1.JPG
NurAida_A_Intel
Mitarbeiter
1.677Aufrufe
Hi Sir,
You can refer to page 28 of this Quartus handbook --> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii5v2.pdf
Please follow the steps provided to assign the Output Enable Group option.
Antworten
