FPGA Intellectual Property
6670 Discussions
How to properly constrain the PFL for STA
Knug
Hi @JohnT_Intel
FPGA_dclk output of the PFL (Parallel Flash Loader). FPGA_dclk is an output of the PFL and gets propagated to my top level wrapper output port. The FPGA_dclk is used normally to configure the FPGA.
How to constrain FPGA_dclk? With an output delay corresponding to the input clock?
I used create_clock command at the input pin (in_clk), the tool should automatically generate the correct FPGA_dclk on the output.
The kit I received for max5 from you specified the following DCLK constraint :
set_output_delay -add_delay -max -clock [get_clocks {clkin_50}] 0.000 [get_ports {fpga_dclk}]
set_output_delay -add_delay -min -clock [get_clocks {clkin_50}] 0.000 [get_ports {fpga_dclk}]
It specified 0.000 output delay.
Is this right?  No delay at all on the output DCLK?
I had a warning "Min rise delay is equal to max rise delay", if use 0.000
So I used :
create_clock -name {clk} -period 100.000 -waveform { 0.000 50.000 } [get_ports {in_clk}]
# Create the associated virtual input clock
create_clock -name {clk_virt} -period 100.000 -waveform { 0.000 50.000 }
set_output_delay -clock clk_virt \
-max 0.001 \
[get_ports fpga_dclk]
-min 0.000 \
But is this right ?
Back to my original question. How do I properly constrain DCLK which is currently an output ? Using set_output_delay ? If yes, please comment on the above in bold. What -max (for setup) /   -min (for hold) values can I use?
Kevin
Knug
Hi @JohnT_Intel
My last 3 Messages to the private email got back :
Delivery has failed to these recipients or groups:
noreply@community-mail.intel.com (noreply@community-mail.intel.com) <mailto:noreply@community-mail.intel.com>
Your message couldn't be delivered. Despite repeated attempts to deliver your message, querying the Domain Name System (DNS) for the recipient's domain location information failed.
JohnT_Intel
I send another email to you so that you can reply to it.
