FPGA Intellectual Property
6669 Discussions
PCIe "Asynchronous Clock" design on A10 FPGA
JET60200
Is there any example design for PCIe HIP that uses asynchronous clock as pcie reference clock in A10 fpga ?
Generally PCIE HIP is required to use the 100 MHz reference clock from the Host PCI Express Connector, which is named as "synchronous clock".   If PCIe uses the 100Mhz on-board reference clock which is "asynchronous clock" system as I know.
On our A10 board, we need use that " 100Mhz on-board reference clock from GPS locked Oscillator " ,  where can we find the ref design example ?
KhaiChein_Y_Intel
Do you mean to connect the refclk pin to internal FPGA generated clock? The input reference clock, refclk, must be stable and free-running at device powerup for a successful device configuration.
KhaiY
KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
KhaiY
