FPGA Intellectual Property
6672 Discussions
I am trying to use modelsim_ae with command line and use the built in libraries. But it doesn't find the -Lf Belowis the command line: But if finds none of the -Lf libraries?
LGlie1
vlog -work tst17301.ulogsim -incr +libext+.bv+.vp+.v+.V+.sv+.vo -sv -sv_pragma -sv12compat -timescale=1ns/1ps +v2k -Lf 220model_ver -Lf altera_mf_ver -Lf twentynm_ver -Lf altera_ver -Lf altera_lnsim_ver
RichardTanSY_Altera
Is using -L instead of -Lf help to find the library?
LGlie1
No. I tried both but made no difference.
RichardTanSY_Altera
Could you help to share the error message?
LGlie1
Its not an Error per say. It doesn't find the modules needed from the libraries.
Referenced (but uncompiled) modules or primitives:
twentynm_io_obuf
twentynm_io_ibuf
twentynm_lcell_comb
dffeas
twentynm_mlab_cell
twentynm_ram_block
altddio_out
altera_iopll
altsyncram
RichardTanSY_Altera
Modelsim-Altera libraries have been pre-compiled for both functional and gate-level simulation. We should not compile the library files before running a simulation.
Document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii53001.pdf#page=page2
Can you run the simulation without the need to compile the library?
Could you help to share the screenshot of your current modelsim-ae GUI with the library on the left-hand side?
RichardTanSY_Altera
Hi, do you able to solve the problem?
