FPGA Intellectual Property
6669 Discussions
I am using IOPLL Intel FPGA IP for Aria 10 SoC device. I need a clock of 307.2MHz/30.72MHz with a ref Clock of 10/100MHz . How can I get the exact clock?
ABhus
With many possible combinations as well, I could get Actual output clock as 307.5M/307.142M/307.189M but not exact value. M,N,C Counter values can be edited only as integer values but not fractional values. Please suggest what can be done.
EngWei_O_Intel
Hi Anamika
Sorry for late response. Can you try to set the PLL mode to Fractional-N PLL?
Eng Wei
ABhus
Thanks for the response.
Actually, in IOPLL there is no option to set PLL mode as Fractional mode.
But there is one fPLL under Transceiver section in which we can use Fractional mode.
Is it ok to use fPLL for driving user logic?
When I tried using fPLL it is giving Fitter placement issues as shown below?
"Error(11215): Input port "REFCLK" of "CMU_FPLL_REFCLK_SELECT" cannot connect to PLD port "O" of "IO_INPUT_BUFFER" for atom "fpga_clk~input". "
EngWei_O_Intel
Hi Anamika
May I know which version of Quartus tools that you are currently using?
For PLL selection, for example in Quartus 18.1 version, we can use:
Basic Functions -> PLL -> PLL Intel FPGA IP
After selecting the IP above, you can refer to doc below for more calculation setting:
https://www.intel.com/content/dam/altera-www/global/en_US/kdb/rd08062012_921/how_fractional_divisor_is_calculated_in_quartus_rev4.pdf
Eng Wei
ABhus
Hi Eng Wei
I am using Quartus Prime 19.1.0 and Arria 10 SoC Device.
For PLL IP Selection, Basic Functions -> PLL -> IOPLL Intel FPGA IP as shown in the image attached.PLL_selection.PNG
For Parameter settings for IOPLL, please refer attached image.PLL_parameter_selection.PNGAs per this, I am not getting fractional calculation settings.
Could you please check these snapshots and revert.
Thanks and Regards
Anamika Bhushan
EngWei_O_Intel
Hi Anamika Bhushan
For Arria 10 device, yup, you can use the fpll under Transceiver PLL. Regarding the fitter issue when you were using the fpll, can you share with us the parameter setting that you are using for the fpll? Or possibly a sample design that you are connecting the fpll?
Eng Wei
ABhus
Hi Eng Wei
I have created one simple counter logic, to make sure fPLL works for user logic. I have attached parameter selction pic for fPLL.
Clock path is FPGA pin -> fPLL input
Output clock from fPLL is used for running a 4 bit counter. Counter bits are given to on board LEDs.
Error: Error(11215): Input port "REFCLK" of "CMU_FPLL_REFCLK_SELECT" cannot connect to PLD port "O" of "IO_INPUT_BUFFER" for atom "fpga_clk~input".
Extra Info(13133): Output port's "O[0]" atom name is "fpga_clk~input".
Extra Info(13134): Input port's "REFCLK[0]" atom name is "u0|xcvr_fpll_a10_0|xcvr_fpll_a10_0|fpll_refclk_select_inst".
Extra Info(12877): Output port "O[0]" of "IO_INPUT_BUFFER" can connect to:
Extra Info(12878):   Port "INCLK[0]" of "CLKBUFBLOCK"
Extra Info(12878):   Port "INCLK[0]" of "CLKSELBLOCK"
Extra Info(12878):   Port "INCLK[1]" of "CLKSELBLOCK"
Extra Info(12878):   Port "INCLK[2]" of "CLKSELBLOCK"
Extra Info(12878):   Port "INCLK[3]" of "CLKSELBLOCK"
Extra Info(12878):   Port "DATAIN[0]" of "DELAY_CHAIN"
Extra Info(12878):   Port "I_INCLK[0]" of "CLKBURSTBLOCK"
Extra Info(12878):   Port "I_RXN[0]" of "HSSI_PMA_RX_BUF"
Extra Info(12878):   Port "I_RXP[0]" of "HSSI_PMA_RX_BUF"
Extra Info(12878):   Port "I_RX_N_BIDIR_IN[0]" of "HSSI_PMA_TX_BUF"
Extra Info(12878):   Port "I_RX_P_BIDIR_IN[0]" of "HSSI_PMA_TX_BUF"
Extra Info(12878):   Port "I_REFCLK_INN[0]" of "HSSI_REFCLK_DIVIDER"
Extra Info(12878):   Port "I_REFCLK_INP[0]" of "HSSI_REFCLK_DIVIDER"
Extra Info(12878):   Port "I_RXP[0]" of "HSSI_PMA_CDR_PLL"
Extra Info(12878):   Port "I_PIN_PERST_N[0]" of "HSSI_GEN3_X8_PCIE_HIP"
Extra Info(12879): Input port "REFCLK[0]" of "CMU_FPLL_REFCLK_SELECT" can connect to:
Extra Info(12880):   Port "O_REFCLK_A[0]" of "HSSI_REFCLK_DIVIDER"
fPLL_parameter_selection.PNGThanks and Regards
Anamika Bhushan
EngWei_O_Intel
Hi Anamika Bhushan
We can refer to the doc below (Section 3.1.3. fPLL) to check if we met the input reference clock spec for the fpll:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf
Fitter will prompt error when certain conditions are not met.
Eng Wei
EngWei_O_Intel
Hi Anamika Bhushan
We do not receive any response from you to the previous reply that we have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Eng Wei
