FPGA Intellectual Property
6673 Discussions
I want to add an array of floating point values and store it in single register using floating point accumulator but unable to understand how to use the ip core.
mdudd
MuhammadAr_U_Intel
Hi, Please refer to Altera Floating point IP user guide to select the IP that serves best to your need. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altfp_mfug.pdf You need to select the IP based on the arithmetic operation you want to perform. Thanks, Arslan
mdudd
Sir actually i want use floating point accumulator ip core in vivado but i am unable to understand some terms like tlast ,which we need to give as input to it .
mdudd
