FPGA Intellectual Property
6670 Discussions
I2C Slave to Avalon MM Master bridge IP - Consecutive Write problem from odd addresses
Nikolay_Rognlien
We have a Qsys system with an I2C Slave to Avalon MM Master bridge IP connected as master to an On-Chip RAM.
When writing consecutive bytes to to the I2C Slave of the "I2C Slave to Avalon MM Master bridge IP" with a start address other than 32bit boundary(like 0x01, 0x02 or 0x03) the transaction is split up on the Avl MM side and two of the data bytes are used as address bytes in the next Avl MM write.
Writing with start address of 0x00 or 0x04 works fine.
Example:
Starting from i2c address 0x5, writing 8 bytes. Data in first byte is 1 and the value is incremented for each write operation. Expected output would be:
Adr
0x5
0x6
0x7
0x8
0x9
0xA
0xB
0xC
Data
1
2
3
4
5
6
7
8
But reading from the same address gives:
Adr
0x5
0x6
0x7
0x8
0x9
0xA
0xB
0xC
Data
1
2
3
0
0
0
0
0
It seems that the data for the fourth and fifth write operation somehow ends up in the i2c address. Reading 16 bytes from i2c address 0x400 gives:
Adr
0x400
0x401
0x402
0x403
0x404
0x405
0x406
0x407
0x408
0x409
0x40A
0x40B
0x40C
0x40D
0x40E
0x40F
Data
0
0
0
0
0
6
7
8
0
0
0
0
0
0
0
0
Doing the same write operation as above, but with a starting data value of 2.
Reading from address 0x5:
Adr
0x5
0x6
0x7
0x8
0x9
0xA
0xB
0xC
Data
2
3
4
0
0
0
0
0
And this time the rest of the data ends up in 0x506:
Adr
0x500
0x501
0x502
0x503
0x504
0x505
0x506
0x507
0x508
0x509
0x50A
0x50B
0x50C
0x50D
0x50E
0x50F
Data
0
0
0
0
0
0
7
8
9
0
0
0
0
0
0
0
This is how the signals look on the external I2C Slave SCL and SDA pins for a consecutive write starting at address 0x05:
Any ideas what may be wrong?
Is it a problem with the IP?
SyafieqS
Hi Nikolay,
Any update on the issue?
