FPGA Intellectual Property
IO standard
ymiler
Hi
I have differential (P/N)   wires in the top of the FPGA (input & output)
My question is  : How can I know which IO standard I should to define
I found out a lot of options to define  :
Differential SSTL-18 Class I 50 100
Differential SSTL-18 Class II 25 100
Differential SSTL-15 Class I 50 100
Differential SSTL-15 Class II 25 100
Differential SSTL-15 34, 40 240
Differential SSTL-135 34, 40 240
Differential SSTL-125 34, 40 240
Differential SSTL-12 34, 40, 60, 120, 240 240
Differential POD12 34, 40, 48, 60 240
Differential 1.8 V HSTL Class I 50 100
Differential 1.8 V HSTL Class II 25 100
Differential 1.5 V HSTL Class I 50 100
Differential 1.5 V HSTL Class II 25 100
Differential 1.2 V HSTL Class I 50 100
Differential 1.2 V HSTL Class II 25 100
Differential HSUL-12
LVDS
Mini-LVDS
RSDS
Where can I find doc. that describe the differences between all the defintion and How  I choose 1 of them ?
The attach doc. doesn't explain when I need to choose each of them  :
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-gpio.pdf
Do you have another doc . ?
Yishay
AminT_Intel
These are the two documents that are mainly being used in designs:
1. GPIO User Guide: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-gpio.pdf
2. Device Datasheet: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/s10_datasheet.pdf
These documents do not explain in details when you have to use the information is enough to know what it does based on the specs given.
Thank you.
AminT_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
