FPGA Intellectual Property
6671 Discussions
IP core instantiation
Can I instantiate an IP core from SOPC in my vhd code? :confused:
I want to make a Modbus slave core and I'd like to use the FIFOed UART (or default UART) component as receiver/transmitter. My vhd code would control the core by accessing its registers (TX,RX,STATUS,CONTROL...) and should do the Avalon interface.
Briefly, I want to control the UART signals that are currently managed by the Avalon interface. Can I do this?
Thanks in advance,
Willian
You've got a couple of options and these depend on the core itself.
1 - Generate a fake SoPC builder system and steal the generated HDL files.
2 - If the component has the HDL code in its install directory, you can steal it from there.
Jake
--- Quote Start ---
Jake
--- Quote End ---
I didn't find the HDL code in its install directory, but the first option helped me.
Thanks Jake..
