FPGA Intellectual Property
6671 Discussions
Interfacing with Altera-MM Salve of UniPHY DDR2 controller
Hi to all....
This is my first post in this forum and my english is not quite good...
I have some problem with a UniPHY interface generated trought Megawizard (Quartus II 13.0 with a Stratix IV device) for the interface with a DDR2 memory.
As I read in the documentation and in this forum I have in the user side an Avalon-MM Slave interface so I used the Avalon specification chapter 3.
I have some doubts
  • respect the sincronizzatio of the avalon interface: The signal ( in particular the avl_ready = not(waitrequest)) changes on the clock edge so if I use a statement like @(posedge clk) I read the state only on the following clock edge cause two read request.
  • Wher i can find the properties of the generated Avalon-MM interface listed in the table 3-2 of the Avalon Specification?
First I must write data in the interface otherwise when I try to read the interface return "x" data.
When I use a write burst size of "1" and make a read request (also with burst size 1) the interface return to two valid data.
Figure 1-1
When I use a write burst size of "1" and make a read request with burst size =3 the interface return 3 valid data but the first two are egual.
Figure1-3
Otherwise when I use a write burst size different from 1 the following read request are ignored.
figure 21
figure 2-3
This is the question... More Important is to find the properties of the interface because I'm not sure on the addressing and data size of the Avalon-MM interface.
Thanks to all!
Edit: Sorry but I can't upload image. Return an invalide file. The image are a .png of size less then 100kb. Suggestion?
