链接已复制
6 回复数
I'm not 100% certain on on the clock is essential, but if you don't add a clock to a DSP builder design then when you compile it you will have no clock definition (as required in the .sdc file) and it will not try to acheive a required Fmax. Also, I think it will need the clock in order to simulate the design in Simulink.
You need to use a clock block to derive the clock rate, else it will just assume it is running at 50 Mhz. You wont find any clock pin in the design, but after you have compile it, from the top level VHDL file, you will notice there is a clock input pin that required to connect to a clock source from hardware.
