FPGA Intellectual Property
6673 Discussions
Is it possible two DDR2 controller use the same PLL?
I wonder that if two DDR2 controller can share a PLL on a CYIII. For example, Run a PLL outputting 166MHz for two DDR2 controller.
I noticed that a option called "use clocks from another controller" under the tab called "controller setting" in the "DDR2 High Performance Controller", and when selecting it, a message below pops up. I have copied it here.
"Info: After Quartus Compilation, check the "PLL Usage" report to make sure that the PLL outputs are merged correctly. Your master controller (altmemddr_0) should have two more PLL related clocks than your (altmemddr_1) controller (this report is in "Compilation Report > Fitter > Resource Section")."
Is it possible?
Please give my some hints, thanks a lot!
Sharing PLLs is possible, as long as the frequency is the same. Just select the option and wire up the other PLL to it in the RTL
--- Quote Start ---
--- Quote End ---
Thanks for reply!
I understand your point, but how to wire up?
Is there any docs on this subject I may refer to?
Thanks again!
--- Quote Start ---
Here is the external memory handbook
http://www.altera.com/literature/lit-external-memory-interface.jsp
--- Quote End ---
Hi, std_logic
Thanks a lot for the link!
I will check it out.
Thanks again!
