FPGA Intellectual Property
6670 Discussions
Max10 speedgrade 8 and DDR2 memory
The MegaWizard tells me that Max10 speedgrade 8 devices are not supported for DDR2 memory interface generation in general.
I've now targeted a speedgrade 7 device and created the RAM interface successfully (at least I think so as TimeQuest reports OK and I have no hardware available yet to test it in reality).
If I then switch back my design to a speedgrade 8 device and recompile it using the previously generated memory interface, TimeQuest still reports positive slack.
So, for now I have two tools reporting two different results.
Is TimeQuest currently not testing properly?
Is the MegaWizard as well as the online memory selector guessing too pessimistic as the result (speedgrade 8 not supported) does not depend on clock frequency and RAM delay settings?
Or what did I do wrong?
tfranke
Even the -8 device able to close timing in timequest, but it do not have any functionality validation on on actual hardware, so we cannot claim it is supported.
I will suggest we refer to EMIF estimator for clearer support scheme.
https://www.altera.com/products/intellectual-property/best-in-class-ip/external-memory/support-selector.html#
Apparently, -8 for Max 10 do not support DDR2.
(This message was posted on behalf of Intel Corporation)
