FPGA Intellectual Property
6672 Discussions
Modelsim 10.1 PE syntax error for "tse_10_100_1000_mac" IP core
I have used "tse_10_100_1000_mac" IP core in my design While verifying the design I compiled the tse_10_100_1000_mac IP core to proceed further with verification activity. But modelsim 10.1 PE is reporting syntax error stating
"** Error : ../../design/ altera_tse_top_gen_host.v (1) : Syntax error, unexpected non-printable character 0x8b
** Error : ../../design/ altera_tse_top_gen_host.v (1) :Syntax error, unexpected $undefined , expecting class"
As it is IP , its files are encrypted and I could not view design file to fix the issue,
Kindly let me know how to resolve this issue.
Additional Info :
Quartus -II 64 bit V13.1.0
ModelSim PE 10.1c
Looking forward for solution.
Thank you for your valuable time in reading thread.
If the simulation model does not exist, the error messages may be issued. Did you use the auto-generated msim_setup.tcl to compile simulation libraries?
Hi kkaibara,
Thanks for your time,
I am using my own script to run simulation,I coded it using vsim commands. Apart from this I am using verilog design files of "tse_10_100_1000_mac" taken from IP core directory, files are as mentioned below ,
1. altera_tse_reset_synchronizer.v (file size : 3 Kb)
2. altera_tse_top_gen_host.v (syntax error in this file- Encrypted file, Size : 62 Kb)
3. altera_tse_mac.v (file size : 18 Kb)
N.R.M
What I did is loading msim_setup.tcl in my custom script like below.
# Triple Speed Ethernet MAC
source ./../altera_tse_sim/mentor/msim_setup.tcl
set QSYS_SIMDIR "./../altera_tse_sim/"
set QUARTUS_INSTALL_DIR "c:/altera/13.1/quartus/"
# Compile device library files
dev_com
# Compile the design files in correct order
com
Where altera_tse is the name of my TSE IP, altera_tse_sim is the silumation lib folder Quartus II software generated. QSYS_SIMDIR and QUARTUS_INSTALL_DIR parameters are used in the msim_setup.tcl.
I have learnt this way from the TSE's testbench. I like that.
From your post I could understand that you were trying to simulate TSE's test bench. But I have written design in VHDL and TSE Ip core design files are in verilog, which i compiled successfully except
I am sharing my batch_run.bat , hoping you will get better clarity on the issue,
vlib work
vlib design
vmap work design
vcom -work design -f lib.dgn
vcom -work work -f lib.dgn
vlog -work work ../../design/altera_tse_reset_synchronizer.v
vlog -work work ../../design/altera_tse_top_gen_host.v
vlog -work work ../../design/altera_tse_mac.v
vcom -2008 -work work -f rtl.dgn
vcom -2008 -work work -f tb.dgn
vcom -2008 -work work ../tests/IF_FPGA_TS.vhd
vsim work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps
move IF_FPGA_TEST.log ../logs/IF_FPGA_TEST.log
move vsim.wlf ../waves/IF_FPGA_TEST.wlf
After running this script compiler is reporting the error.
I have directly copied TSE's design files from quartus TSE directory to my design folder.
You must compile all files listed in the msim_setup.tcl to run your custom testbench. They are not only for the TSE’s testbench. This is because altera_tse_mac.v calls many sub-modules in *_sim folder and device specific primitives in Quartus II install folders. You can find the file list in the msim_setup.tcl and can copy them to your script. But the easiest way is calling the msim_setup.tcl in your script as I described before.
If I run your testbench, and if the target device is Arria V, I will do this.
vlib work
vlib design
vmap work design
# vlog -work work ../../design/altera_tse_reset_synchronizer.v
# vlog -work work ../../design/altera_tse_top_gen_host.v
# vlog -work work ../../design/altera_tse_mac.v
dev_com
com
# vsim work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps
vsim -L work -L work_lib -L i_tse_mac -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_ver -L arriav_ver -L arriav_hssi_ver -L arriav_pcie_hip_ver work.IF_FPGA_TB -l IF_FPGA_TEST.log -do msim.do -c -quiet -t 1ps
Please remember necessary files must be placed in proper folders the msim_setup.tcl refers to.
Thank you kkaibara , I will check it.
Hi kkaibara,
I am using my own "run.do" file as below (snippet)
set ETH_DIR "../TSE_10_100_1000_MAC"
vlog -work work ${ETH_LIB}/altera_tse_reset_synchronizer.v
vlog -work work ${ETH_LIB}/altera_tse_top_gen_host.v
vlog -work work ${ETH_LIB}/altera_tse_mac.v
vcom -work work ${ETH_DIR}/tse_10_100_1000_mac.vhd
