FPGA Intellectual Property
6673 ディスカッション
Multiply and Accumulate Intel IP Core
Mathiazhagan
初心者
879件の閲覧回数
Hi All,
       Am using cyclone V E Version development board, am developing a project with the help of intel IP Cores, I could not find a IP for multiply and accumulate, after searching in google i came to know that cyclone V does not have a IP named Multiply and accumulate, Instead of it can use Multiply and adder so anyone please help me out how to realize the function (D-A)*B using the ipcore available,
Thanks in Advance
0 件の賞賛
5 返答(返信)
YEan
従業員
863件の閲覧回数
You may use Intel FPGA Multiply Adder IP Core to realize your function. You can refer to this https://www.intel.com/content/www/us/en/docs/programmable/683490/20-3/intel-fpga-multiply-adder-ip-core.html guideline to select the parameters.
Mathiazhagan
初心者
850件の閲覧回数
Hi there,
Thanks for the reply from your side, I went through the document shared related to the IP FPGA Multiply Adder, In this after product operation am able to add or subtract, Moreover am not able to find a way to implement my function, So kindly let me know how to implement the function (D-A)*B.
If possible please share me the tutorial along with it
V. Mathiazhagan
YEan
従業員
837件の閲覧回数
Hi V. Mathiazhagan,
Has this issue been resolved?
Ean
Mathiazhagan
初心者
832件の閲覧回数
Dear YEan,
    No, Even though i went through the document u have shared am not able to find a solution, Still am working on it if i got done with it definitely i will let u know, Meanwhile if u have other tutorial related to it please share.
Thanks in Advance
YEan
従業員
824件の閲覧回数
Hi V. Mathiazhagan,
This was an older version of user guide but it expressed each mode with equation https://manualzz.com/doc/4172591/integer-arithmetic-ip-cores-user-guide . You may look at pg 57, your function can implement by pre-adder input mode. After you had customize the IP, you may just have to add a Verilog or VHDL file to declare your input and output.
Ean
返信
