FPGA Intellectual Property
6665 ディスカッション
NCO v 11.1 not working
名誉コントリビューター II
2,040件の閲覧回数
I have Quartus v11.1 Build 216 and generate NCO by his Wizard, generating include Simulation Model and Netlist. Then i try simulate this in Altera ModelSim and NCO not working. I use original TB generated by wizard and NCOout make only "U" I expected sine wave, not U. Where I made mistake?
Thanks for any help.
0 件の賞賛
8 返答(返信)
名誉コントリビューター II
861件の閲覧回数
Did You initialize Your signal values?
名誉コントリビューター II
861件の閲覧回数
--- Quote Start ---
--- Quote End ---
Yes, they should. I use to initialize "ALT_NCO_tb.vhd" which be automaticly generate with NCO core. Or do You mean somethin different? I attach TB (ALT_NCO_tb.vhd.txt)
名誉コントリビューター II
861件の閲覧回数
initialize all signals, e.g.:
signal reset_n : std_logic := '0'; signal sin_val : std_logic_vector (MPR-1 downto 0) := (others => '0');
名誉コントリビューター II
861件の閲覧回数
--- Quote Start ---
--- Quote End ---
I paste this lines into my TB. It initialize zero value but NCO still not working. Initialize in attach.
名誉コントリビューター II
861件の閲覧回数
You have to do this for ALL signals. But anyway, I believe the problem is somewhere in other place.
名誉コントリビューター II
861件の閲覧回数
yes, initialization do only the "0" from the "U", but not from NCO sinusoidal wave
名誉コントリビューター II
861件の閲覧回数
There may be other problems, too, but setting reset_n to '0' will keep the NCO in reset. You should only pulse it low.
名誉コントリビューター II
861件の閲覧回数
We have right, the problem was some other. I forgot attach source file generated from BDF in NativeLink settings.
I overlooked ModelSim's Warning: (vsim-3473), that is already described here.
thx for help
返信
