FPGA Intellectual Property
6670 Discussions
Overlay moving (live) graphics feed on video
I need to mix a live graphics image (Streaming into the FPGA) that has a special pixel value in places where VIDEO should show through. I know that the Alpha Blending Mixer can do this, if I can sample the graphics stream and create an ALPHA Channel with it.
I need to see how to use the alpha channel (I can't find any examples) and use this data to enable the underlying video to overlay the graphics on a video stream.
Thanks, in advance.
Mike
try this for liminance.
output = pixel/256 *(256-alpha) + graphics/256 *alpha
As for chrominance - good luck. It might be easier to convert it all into the RGB colour space before mixing if you want to mix in colour.
--- Quote Start ---
--- Quote End ---
Thanks, but I need ti create the alpha channel and I also need to see an example of how to connect the alpha channel in SOPC.
MIKE
have the same problem:
i need to configure alpha blending on DE2 without using CPU
I've found some information about Alpha Blending Mixer over google with next request:
alpha blending mixer sopc example
but in every manual NIOS processor is used
does anyone have sth much useful, like working examples?
