FPGA Intellectual Property
PCIe Memory write TAG
EastGun-A
초보자
3,310 조회수
hello, i wonder about the pcie protocol.
i just know memory write request don't need completion.
then, why tag bit is essential??
is any function in memory write request???
tag bit do the ordering each request??
then additional question is how do pcie ordering about continuous write request?
i mean, If 100 consecutive MWr requests come in, they may not come in order due to a link problem. How do pcie manage the order?
I'm sorry that I can't speak English well.
Thank you for your reply.
0 포인트
1 솔루션
Wincent_Altera
3,183 조회수
Based on my understand the answer is No, there is no additional function specifically for correcting the order with tag bits when applying relaxed ordering in a posted write request. The purpose of relaxed ordering is to allow certain reordering of memory operations for improved performance, but it does not involve any specific mechanism to correct the order with tag bits. If you require a specific ordering of memory operations, you should use a different memory ordering model or synchronization techniques such as fences or barriers. Please correct me if you feel I am wrong.
Wincent_Intel
원본 게시물의 솔루션 보기
0 포인트
10 응답
Wincent_Altera
3,274 조회수
For the tag bit information, I found one article.
It may answer all of your question.
https://www.linkedin.com/pulse/pci-express-primer-3-transaction-layer-simon-southwell/?trk=pulse-article_more-articles_related-content-card
second question.
PCIe ordering rules ensure that all memory transactions, including continuous write requests, are executed in a predictable and reliable manner. The PCIe ordering rules specify how read and write operations should be ordered in time and how they should interact with other transactions on the bus.
For continuous write requests, PCIe ordering guarantees that the data is written to the target memory in the order in which it was sent by the initiator. This is achieved through a combination of various mechanisms such as the Memory Write and Invalidate (MWI) command and the Non-Posted Write (NPW) protocol.
In NPW protocol, the data is written to the target memory without waiting for any acknowledgement from the receiver. The receiver, in turn, sends an acknowledgement once the write operation is complete. The MWI command is used to invalidate the cache lines in the memory hierarchy of the receiving device so that the updated data can be fetched from memory.
Overall, the PCIe ordering rules ensure that all transactions on the bus are executed in the order in which they were issued, regardless of the type of operation or the devices involved. This ensures that continuous write requests are processed in a reliable and predictable manner, without any loss or corruption of data.
Hope this answered your question. let me know if further clarification is needed.
Wincent_Intel
EastGun-A
초보자
3,263 조회수
Thank you so much for your reply.
Then, in the case of posted memory write, does it matter what the tag bit is?
I wonder if it is possible to arbitrarily change the tag bit for posted memory write.
0 포인트
Wincent_Altera
3,231 조회수
Hi
The tag bit in a posted memory write generally does not affect the behavior or outcome of the write operation itself. The tag bit is typically used for tracking and identifying specific memory regions or access types, but it does not directly impact the actual write operation.
Changing the tag bit for a posted memory write may be possible depending on the system and the specific implementation of the memory controller. However, it is important to note that altering the tag bit arbitrarily could potentially disrupt the memory system's intended behavior and could lead to unpredictable results or errors.
Wincent_Intel
EastGun-A
초보자
3,223 조회수
Thank you so much for taking the time for me.
In addition, in the avalon streaming interface, the payload limit is 512B and the read request limit is 4096B. Then, is the completion with data created by automatically splitting the TLP into multiple pieces in the P-tile? (I wonder if the address is automatically changed and the TLP is created.)
0 포인트
Wincent_Altera
3,183 조회수
In the Avalon streaming interface, the payload limit refers to the maximum size of a single data payload that can be transferred in one transaction, which is 512 bytes. The read request limit, on the other hand, specifies the maximum size of a read request, which is 4096 bytes.
If a read request exceeds the payload limit, it needs to be divided into multiple transactions. This division and subsequent reassembly of the data is typically handled by the Avalon interface itself, or by the hardware or software components connected to it. The address may be automatically adjusted for each transaction to retrieve the appropriate data, and multiple Transaction Layer Packets (TLPs) may be generated to transfer the complete data.
The specific implementation details may vary depending on the design and configuration of the system using the Avalon interface, but the interface itself provides mechanisms to handle larger requests by splitting them into multiple transactions as necessary.
Wincent_Intel
0 포인트
EastGun-A
초보자
3,195 조회수
Oh, is there an additional function to correct the order with tag bits when applying relaxed ordering in the posted write request?
0 포인트
Wincent_Altera
3,184 조회수
Wincent_Intel
0 포인트
Wincent_Altera
3,117 조회수
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
0 포인트
EastGun-A
초보자
3,083 조회수
Sorry for the late reply.
Thank you so much for answering my question.
have a good day!
I think the forum can be closed! I'll ask another question next time. thank you
0 포인트
Wincent_Altera
3,073 조회수
Hi
Thanks for your confirmation on the answer
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
0 포인트
응답
