FPGA Intellectual Property
6670 Discussions
PCIe SRIOV Avalon Stream Gen 3 automatically generate locked read request
PPham3
Hi all,
I have a problem with PCIe SRIOV avalon stream. I used SRIOV example design but tried to take the tx stream and rx stream out of the APP function. When I get those signal to signaltap. I noticed that some unwanted packet just streaming down through rx stream though the sw did not write or read anything. The packet format look like a locked read request( 8 lsb bits are 0x01h). Is this issue happens to anyone? How to get it work? Thanks.
SengKok_L_Intel
You need APPS in order to make your design fully function. Without the APPS, the Host should still detect end points, and I don't aware any specify signal need to be connected.
Regards -SK  ​
SengKok_L_Intel
The lock request is performed between a Root Port and the Legacy Endpoint. Perhaps, you may provide more information like what device you are using, or what application you are running and observe this behavior. ​Are there a concern of memory read or write request?
PPham3
I made a mistake. It was not a read req message, it's type just appears to be broadcast message from root complex. Just dont know why this message is automatically sent down.
By the way, when I use the hard ip only, pcie is not detected through lspci from linux. Everything works when using example design, anyone faces this problem?
Thanks​
SengKok_L_Intel
I assume that you are removed the APPS from the design but left the DUT alone. If this is the case, the OS should be still able to detect the PCIe end point.
Regards -SK Lim​
PPham3
You were right. I removed the apps and kept dut. PCIE was not detected.
SengKok_L_Intel
You may need to check if the LTSSM still achieve L0 after rebooting the PC, if yes, the end point should be there.
Regards -SK Lim
PPham3
Hi SK Lim,
I did not check LTSSM signal. Was that signal meaningful for simulation only?
Still can not bring PCIe up without the APPS part? could you please give me a hint about connection? what the APPS really does to make this design work?
SengKok_L_Intel
Removing the APPS, by right the Host should can still detect the end point. Check the LTSSM is to ensure the Link is still up. The host is not able to detect end point IF the LTSSM can't achieve L0. The APPS is required to decode and process the Header for Memory Read/Memory write TLP.
Regards -SK​
SengKok_L_Intel
​Anyhow, you need the APPS to process the Memory read/Memory write and create the completion TLP. You can use the APPS in the example design to modify or update based on your design requirement. Or you can create your own APPS. It does not make sense to left the Avalon ST unconnected.
Regards -SK Lim
PPham3
the reason why I do not want to use the APPS is to generate 4 PFs. at this point, the APPS is not supported (maximum 2 PFs for the APPS).
Still many thing to work since when I generate 2 PFs via example design, each PF has 8 VFs. The linux lspci can detect 1 PF and full 8 VFs, still one more PF missing. Is there any special signal that must be connected to make this design work
Thanks so much, SK Lim.
SengKok_L_Intel
Regards -SK  ​
PPham3
Okay, thank you. It seems that I need to make it out on my own.
