FPGA Intellectual Property
6673 Discussions
PCIe MM-DMA has no option for going to/from FIFO?
Do I understand the documentation correctly, that there is no option for sourcing DMA writes from a FIFO (inside the FPGA) or sending DMA reads to a FIFO? If that is the case, are people using buffers to get data from the DMA to a FIFO?
clair
Hi, do u have find a way to solve the problem? I want to add a fifo to transfer data with pcie too. But I can't think out a way. Would u like to share your thoughts with me? Thanks a lot!
