FPGA Intellectual Property
6669 Discussions
PCIe chaining dma example test failed
Hi All:
I used PCI express compiler 7.2 in my porject with quartus II 7.2. The PCI Express MegaWizard auto generated two examples:chaining dma and simple dma.
I simulated the chaining dma example with runtb.bat in \chaining_dma\testbench. After standard DMA read(data is transferred from BFM shared memory to ep memory) and DMA write(data is transferred back from ep mem to the BFM shared mem) test,the testbench failed in data integrity check. It's reported that the write data not equal with read data. I found all of the DMA write data in the BFM shared mem are zero.
Any suggestion?
-huzj_ecc
If you post the <variation_name>.v file (so that I could recreate the exact same variation and examples) I might be able to take look and see what is wrong.
Thank you for reply.I have solved my problem.Because when using Modelsim se 6.2 or 6.3f to simulate the example,there is an optimization problem with the ALTSYNCRAM module.I disabled the optimization option followed the solution:
http://www.altera.com/support/kdb/solutions/rd05052008_373.html?gsa_pos=1&wt.oss_r=1&wt.oss=rd05052008_373
It works well now.
