Dear Intel Community and Intel Employees,
I need to place one PCIe Gen1 x1 hard IP block and 4 SerDes Transceiver Channels of an third party IP of an switch into a Cyclone V GX with 6 transceivers (5CGXFC7C6U19I7).
triplet | transceiver | usage |
0 | 0 | PCIe hard IP |
0 | 1 | unused / CMU of PCIe |
0 | 2 | SerDes HSR ring 1 : Port 0 |
1 | 3 | SerDes HSR ring 1 : Port 1 |
1 | 4 | SerDes HSR ring 2 : Port 0 |
1 | 5 | SerDes HSR ring 2 : Port 1 |
but I get the error:
Error (11687): Channel GXB_SFF_TX[1](n) is assigned to location PIN_N1, channel oPcieTx(n) is assigned to location PIN_Y3, however channels with different reconfiguration controllers cannot be placed in the same channel triplet. Modify your design so the two channels share the same reconfigure controller.
Is there a workaround for this error, when I have no place in the other triplet left ?
kind regards,
Martin
Thanks for contacting Intel. I'm assigned to support request.
I'll investigate on this case and get back to you soon once I have any finding.
Meanwhile can I check with you on:
- Quartus version you are using?
- Are you able to share your design or something with we can regenerate the same error?
Thanks for your patience.
Harsh M
Dear Harshx,
1. We use: Quartus Prime 18.1.0 Build 625 - Standard Edition
2. I 'm not able share the Design, because of Encrypted Third Party IPs and company knowledge.
When I separated the channels into the other Triplet, I ran into another problem:
Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 Channel PLL(s)).
In the Transceiver Manual I found the Note, that for Full-Duplex communication, the Tx-path needs a CMU PLL which are sourced from channel PLL 1 and 4 in Cyclone V GX.
The only setup where the fitter can place was by only using 2 out of 4 SerDes transceiver channels.
Chip-Planner 5CGXFC7C6U19I7:
So, currently 3 of 6 transceivers are used that the fitter can place the channels.
We need 2 additional SerDes transceiver channels for our design, this would be 5/6 transceivers.
→ Is there a Solution to use PCIe hard IP with more than 2 SerDes Transceivers?
kind regards,
Martin Haiden
These issues could be due to the way you have split up your reconfiguration controller, where the minimum "granularity" is a triplet, or perhaps the channel placement is constrained because you are using CMU PLLs, which can only be placed in CH1 or CH4 of a 6-pack.
I believe that you should check the clock sharing and the data rates that you are targeting within a bank. Please check the PLL sharing guidelines: 1.5. PLL Sharing
