FPGA Intellectual Property
6670 Discussions
PCIe problem with large TLPs
I'm sending a TLP (from the application layer) of 4 headers and 128 bits of data (Avalon-TX 128).
Headers look like this:
header0 = 32'h60000004; //fmt = 3, length = 4 DW
header1 = 32'h000000FF; //first BE = F, last BE = F
header2 = 32'h00000000;
header3 = address; //that is 32-bit wide
Afterwars I send it like this:
tx_valid_next = 1;
tx_data_next = {header3, header2, header1, header0};
tx_sop_next = 1;
Next cycle: sending the data
tx_sop_next = 0;
tx_valid_next = 1;
tx_data_next = data; //that is 128-bit wide
tx_eop_next = 1;
Next cycle: deasserting eop and valid. Also checking TX_ready before asserting TX_valid.
problem:
When I use shmem_display, it shows all zeros, whereas it all works fine with the code like this:
//3 DW headers, 32-bit data payload, single transaction
header0 = 32'h40000001;
header1 = 32'h0000000F;
header2 = address;
tx_valid_next = 1;
tx_data_next = {data, header2, header1, header0};
tx_sop_next = 1;
tx_eop_next = 1;
What am I missing?
The PCIe spec says:
--- Quote Start ---
• For Addresses below 4 GB, Requesters must use the 32-bit format.
--- Quote End ---
So, in your TLP generator you have to check the upper 32 bits of the address to be zero and use a 3 word TLP in this case.
It worked with 3DW headers! Thanks!
