- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
Background :
I am currently using the Arria 10 GX Devkit in preparation for a similar custom board. I have adapted the PCIe Avalon-MM DMA example which Intel provides and come up with a custom design which fits my needs in the moment. I am using Quartus 19.3 pro.
Problem :
The memory sector sizes which are returned when I run 'lspci' do not match those which I set in Platform Designer.
I have attached "pd_component" which shows the overall design of the platform designer component.
I have also attached "lspci_output" which shows what the command returns when the devkit is slotted in.
The table below shows the settings I input into platform designer and the lspci reported size
Bar# | Data Width | Total Memory(B) | Base | End | lspci |
2 | 32 | 32000 | 0x0000 | 0x7cff | 32K |
3 | 8 | 5000 | 0x8000 | 0x9387 | 64K |
4 | 32 | 4000 | 0xa000 | 0xaf9f | 64K |
5 | 256 | 1024 | 0xb000 | 0xb3ff | 64K |
Question :
How to I ensure the 'lspci' command returns the correct sizes of these memory sectors?
Thank you for your help.
Link copiato
- Preferito
- Iscriversi
- Evidenziare
- Stampare
The BAR2 requires 32KB so that size is assigned to this BAR.
Though BAR3 requires only 5KB, a 64KB is assigned to this BAR because of the END addr 0x9387. Similar situation to BAR4 and BAR5.
Rong
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Any further questions?
- Preferito
- Iscriversi
- Evidenziare
- Stampare
I need the lspci command to return the correct sizes of the memory BARs. Lets say I have 3 memory regions of 4KB how would I align these in memory such that lspci returns 4K for their respective sizes?
- Preferito
- Iscriversi
- Evidenziare
- Stampare
For these 3 BARs, you assign addr 0x0-0xfff each in qsys.
Rong
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Assigning the address 0x0-0xfff for each on-chip RAM will result in an error because you are mapping 3 different RAM modules to the same memory region. Attached is a picture of the error.
To clarify there is a previous project which has different memory modules mapped to different regions and the lspci command returns the correct sizing of these BARs, i.e. there is a 4K BAR not mapped to 0x0-0xfff. Unfortunately this project was done in AHDL and I do not have the time to decode it.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
If you want multiple Bars to access one on-chip mem, please try AVMM Pipeline Bridge IP. You can define your address width there.
Rong
- Preferito
- Iscriversi
- Evidenziare
- Stampare
This is not the accepted solution. I already have multiple BARs. I never said I wanted them to access one on-chip mem. Maybe it is the accepted solution for YOUR problem but it is not what I asked.
I have multiple BARs access multiple on-chip Mem and it is working fine other than the lspci command does not reflect the correct size. I have moved on to other problems of more importance now. When I have time to investigate this again I will.
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
