FPGA Intellectual Property
6670 Discussions
Passing real parameters from Qsys (platform designer) to the custom IP core.
I have developed a custom IP core which uses some calibration information, this information is passed to the top level entity.
However, I have generated the *_hw.tcl file for the qsys (platform designer) and it appears that it cannot pass any floating/real type parameters (there is no support) and converts these parameters to string data type.
So, then I thought that I can simply convert types: from "string" to "real". In VHDL2008 standard there is t'value(x) attribute, which converts string X to value of type T, BUT sadly this is not supported for "real" data type :(
Has anyone encountered this problem? Is there a solution without manually writing coefficients in source files every time I generate Qsys system?
Cheers,
Rihards
'value is not just a 2008 attribute.
You could write a function to do the conversion yourself.
Ou.., I wanted to express that even in VHDL2008 standard 'value attribute does not support real data type.
But thank You, I'll write my own function.
My straight forward implementation for future reference:
-- synopsis directives: -- synthesis VHDL_INPUT_VERSION VHDL_2008 library ieee; use ieee.std_logic_1164.all, package functions is function to_real( str:string ) return real; end package; package body functions is function extract_exponent_value( str_exp:string ) return real is variable i : natural; variable is_inverse : boolean := false; variable ret : real := 0.0; variable digit : natural; begin for i in str_exp'low to str_exp'high loop -- skip character if it exists if (str_exp(i) = 'E') or (str_exp(i) = 'e') then report "Exponent sign"; next; end if; -- we can safely skip '+' sign if (str_exp(i) = '+') then report "Plus sign"; next; end if; -- is exponent 'negative' if (str_exp(i) = '-') then report "Minus sign"; is_inverse := true; next; end if; digit := integer'value(str_exp(i to i)); ret := ret + real(10)**( digit*(str_exp'high-i+1)); report "Exponent: " & real'image(ret); end loop; -- if is_inverse then ret := 1.0/ret; end if; return ret; end function; function extract_exponent( str:string ) return real is variable i : natural; begin -- finc exponent for i in str'low to str'high loop if (str(i) = 'E') or (str(i) = 'e') then return extract_exponent_value( str(i to str'high) ); end if; end loop; -- if there was no exponent, let's return identity return 1.0; end function; function to_real( str:string ) return real is variable i : natural; variable pos_decimal : natural := 0; variable pos_start : natural := str'low; variable pos_end : natural := str'high; variable is_negative : boolean := false; variable exponent : real := 1.0; variable ret : real := 0.0; begin -- check for negative sign if( str(str'low) = '-') then pos_start := str'low + 1; is_negative := true; end if; for i in pos_start to pos_end loop -- get decimal point position if( str(i) = '.') then pos_decimal := i; next; end if; -- check if exponent form if (str(i) = 'E') or (str(i) = 'e') then exponent := extract_exponent(str); pos_end := i-1; exit; --report "Exponent form is not supported!" severity FAILURE; end if; end loop; -- whole digits for i in pos_start to pos_decimal-1 loop ret := ret + real(integer'value(str(i to i))) * (real(10)**(pos_decimal-i-1)); end loop; -- fractional digits for i in pos_decimal+1 to pos_end loop ret := ret + real(integer'value(str(i to i))) * (real(10)**(pos_decimal-i)); end loop; -- inverse the value if necesarry if is_negative then ret := -ret; end if; -- multiply by our exponent value ret := ret * exponent; report "string '" & str & "' converted to " & real'image(ret); return ret; end function; end package body;
