FPGA Intellectual Property
6673 Discussions
Propagation Delays for DSP Builder primitives?
Hello!
How can one fine the Propagation Delays for DSP Builder primitives?
How could the simulation in Modelsim-Altera be done in 'post-place and route' mode? while using "TestBench" block from DSP Builder blockset.
In my design even I use primitives (like simple/complex multipliers and adders, divider, etc ) with 0 pipeline stage, still ModelSim shows 12 clock cycle for results to become stable.
If I use this design with constant inputs it produces correct results (not sure but may be with 12 cycle delay of default clock). How can it be fitted within a system running at certain clock frequency?
Thank you!
Best regards-
are you using Advanced Blockset?
No Sir. I am using 'Altera DSP Builder Blockset'. Version 11.0.
