FPGA Intellectual Property
6670 Discussions
Quartus II Lite 19.1 Linux, Cyclone 10 LP dev kit. Nios 2 error. How do I update IP core ?
JLuke3
Error (292019): IP core Nios II Processor (6AF7_00A2) not supported in device family Cyclone 10 LP. Choose a new device family or upgrade your IP core to a newer version. The Intel FPGA Knowledge Database contains many articles with specific details on how to resolve this error. Visit the Knowledge Database at https://www.altera.com/support/support-resources/knowledge-base/search.html and search for this specific error message number.
Database only tells me about 17.1 bug to be fixed in future releases.
John Luke
Vicky1
Would you like to share the project file *.qar file(Project menu->Archive Project) for replication?
Vicky
JLuke3
Dear Ms. Vicky, Am trying to port a Terasic DE1 (Cylone II) project to my Cyclone 10 LP dev kit to experiment with i2s drivers as part of a project to build an audio digital filter (convolved). The original source came from https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=53&No=83&PartNo=4 My qar file is attached. Compiles OK for Cyclone IV but not for 10 LP. Thanks for your prompt response Regards John Luke
Vicky1
Hi John,
Thanks for the details but There is no .*qar (Project file) attached.
Could you please attach the project file again & confirm it after posting it in community?
Mr. Vicky
JLuke3
Dear Ms. Vicky, That is strange. The mail was sent from apple mail on a MacBook pro. The attachment shows in the entry in my sent folder and in the test mail I forwarded to myself. You may be the victim of some sort of anti virus software. Try another mail reader or try reading on a mac. Should I try something old fashioned like uuencoding the file and sending it as a text file ? Will attach the file again. Regards John Luke
JLuke3
Dear Vicky, Maybe it is the forum that is filtering out .qar files. IP concerns ? Your email server did not like my reply either. Have copied emails. You should also be able to recreate the problem by downloading from the Terasic link https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=53&No=83&PartNo=4 and changing the family and device to 10CL025YU256I7G. Here goes again. Regards John Luke
Vicky1
Hi John,
Here I am attaching the *.qar file for sample and there is no any concern with IPs also, I have been doing it since long time.
let me check by recreating the issue.
Vicky
Vicky1
JLuke3
Interesting maybe it makes a difference if done from inside Intel ?
The attachment was definitely on the email as it was sent out.
Will try from web page reply instead of email reply..
Seems to have worked.
John Luke
Vicky1
The provided design contains verilog HDL files generated from some Mega-wizards like PLL etc. also it contains the cpu_0.v which is encrypted. so Cyclone II & Cyclone IV E devices are compatible to this design & hence design compiled successfully, since this design is provided by Terasic & there is no update about other supported devices for this design. I would like to suggest try to use same devices & supporting Quartus versions recommended by Terasic.
Vicky
