FPGA Intellectual Property
6670 토론
Questions about using Remote Update IP core
RobertLiang
새로운 기여자 I
886 조회수
Hello, I'm using Remote Update IP core in my design. The device is cyclone 10LP, and the configuration device is EPCQ64A.
I set the boot address of the application image as 0x400_000 which is half of the address space of the flash device.
But when I was debugging my design, I found that, although the application image was loaded on the FPGA, the value of the boot address of this image I read was wrong.
I wonder if there's any detail I ignored? The parameters I set were as follows.
And the value I read is 0x1_000_000 which is wrong.
Thank you!
0 포인트
1 솔루션
NurAiman_M_Intel
842 조회수
Thank you for contacting Intel community.
Apologize for the delay in response as this case was only routed to me today.
  1. I am assuming you have follow this design example, but having problem with the boot address?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altremote.pdf
2.Please let me know if my understanding is correct or not. If you are following the design example, do you check on the design example?
https://fpgacloud.intel.com/devstore/platform/17.0.0/Standard/cyclone-10-lp-remote-system-update-design-example/
Aiman
원본 게시물의 솔루션 보기
0 포인트
2 응답
NurAiman_M_Intel
843 조회수
Aiman
0 포인트
NurAiman_M_Intel
828 조회수
Any update fort this request? Else, I will proceed to close this case.
Aiman
0 포인트
응답
